Activity › Forums › Apple Final Cut Pro Legacy › Olympia DV-777HD footage
Posted by Andrew Paul bowser on June 16, 2010 at 6:05 pmI am trying to bring in footage from an SD card into Final Cut Pro and I am not getting video, I am only getting audio.
It is from an SD card out of an Olympia DV-777HD camcorder.
Thoughts?
Rafael Amador replied 16 years, 3 months ago 3 Members · 5 Replies -
Jerry Hofmann
June 17, 2010 at 2:44 pmNot sure what that camera records file/compressor wise, but bet it’s h.264 or some variant. FCP cannot edit this footage directly, but MPEG Streamclip can be used to transcode it to an editable format such as ProRes… Just google it… it’s free too.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
Andrew Paul bowser
June 19, 2010 at 7:40 pmI’ve tried converting the clips to Apple Pro Res in MPEG stream clip, it still won’t show any video- only audio.
Where to from here?
Rafael Amador
June 20, 2010 at 1:36 am -
Rafael Amador
June 20, 2010 at 2:08 amHi Andrew,
I see. The problem is not on FC, but on the camera.
I’ve been having a look to that camera in Google. and no idea what kind of format may records.
have you got any clue?
rafael
