Activity Forums Panasonic Cameras Older Powerbook Titanium (will it work?)
  • Older Powerbook Titanium (will it work?)
    Posted by Tunaking on February 2, 2006 at 7:58 am
    I have a Powerbook Titanium that has the card slot for the P2, but it’s not fast enough to run FCP 5.0.4. Can I still use this to drag the media off the P2 cards?
    What would the workflow be?
    My guess is…
    1) If it works, insert P2 into old Powerbook.
    2) Drag media folder, the whole thing, to a Firewire Drive (I might use a RAID 5 Firewire drive, like the Platinum RAID…).
    3) Plug the FireWire drive into a Laptop that can run FCP 5.0.4 (a 12″ 1.5 GHz) and convert the files to QuickTime. (Do I toss the original unconverted media folder on the FireWire drive when FCP is done?)
    4) Reformat P2 card? Erase? How do I do that with the Old Powerbook. Can I screw up the card somehow?
    Don’t have the camera yet, but we’ll be shooting with it this weekend. That’s why I’m speaking in hypotheticals.
    Any insight?
    Tunaking replied 20 years, 7 months ago 3 Members · 3 Replies
  • Barry Green
    February 2, 2006 at 10:00 am
    That should work; you’d have to download the driver from the Panasonic website. I don’t know if there are any limits on which systems the driver will work on, I would think it would work.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Jan Crittenden livingston
    February 2, 2006 at 11:37 am
    This may mean that there is something that the PCMCIA driver needs to see is not there, so unfortunately this is very hypothetical.
    Make a folder, call it Whatever, Card One, Drag the contents folder into the Newly created folder.
    Only if you are sure that you will never take it to a PC platform.
    Delete the files by doing an Option Delete, including the last little txt file.
    Good luck, as I said, I am not sure the PCMCIA exe that comes with the camera will load without 5.04. So if it doesn’t don’t be surprised.
    Best,
    Jan
    Jan Crittenden Livingston
    Product Manager, DVCPRO, DVCPRO50, AG-DVX100
    Panasonic Broadcast & TV Systems
  • Tunaking
    February 4, 2006 at 3:31 pm
    Update… We finally got our hands on the HVX200. I downloaded the P2 driver for the Powerbook and loaded it onto an old Titanium Powerbook (which cannot run FCP 5).
    I slid in the P2 card and the Powerbook successfully saw the card. I made a new folder on a firewire drive, copied the media over to it.
    Then I took the drive and attached it to my 1.5 GHz 12″ Powerbook and using FCP 5.0.4 successfully imported the footage.
    So, in the end…we don’t need to buy a new 15″ G4 Powerbook. The old clunker works!
