Activity Forums Media 100 old vari speed clips not working in new M100HD
  • old vari speed clips not working in new M100HD
    Posted by Ted Joyce on November 10, 2009 at 11:04 pm
    I got the trial of the new HD version of M100 primarily to work with old 8.3 M100 NTSC projects (many of the shots are varispeed clips) I open the old project in M100 1.1 and the varispeed clips are linked but not in the right place, leaving black gaps. I tried exporting out of the M100 via XML and I tried all the export options the problems remain in Final Cut, all vari speed clips were still partially missing the underlying clips or missing completely.
    Is this a known bug?
    Ted Joyce replied 16 years, 9 months ago 2 Members · 6 Replies
  • Wickham Strub
    November 11, 2009 at 3:08 am
    Hmmm… it’s NOT a known issue.
    What else can you tell us about the project?
    – Dropframe or Non-Drop timecode?
    – 720×486 or 640×480?
  • Wickham Strub
    November 11, 2009 at 3:12 am
  • Ted Joyce
    November 11, 2009 at 4:59 am
    I tried reloading the old M100 into the new M1000HD & it works ok now (I had got a -19308 error, don’t know why its ok now), the problem shows up in the XML export to Final Cut 7. The new M100HD timeline is nondrop NTSC 720×486. Final Cut gives me a log of errors when importing the XML file.
    I’ve a Kona3 that works fine with Final Cut7 & gives an SDI out when running the M100HD software.
  • Wickham Strub
    November 11, 2009 at 2:18 pm
    When exporting to XML are you choosing the option to include rendered filter media?
  • Wickham Strub
    November 11, 2009 at 4:47 pm
    Okay… forget that last question.
    I was just able to sit down and replicate your scenario and I think I may be seeing the same thing.
    I am able to trim the clips out to fill the gap, at which time they play as expected. Can you do this also?
    I am going to run this by Engineering now to see what they think about it.
    ~Wick
  • Ted Joyce
    November 12, 2009 at 4:34 am
    Yes that is what I’ve been seeing.
    I’ve been working now for hours on two different newly converted M100HD programs & discovered the major problem. If I unrendered the realtime preview files or turn of and then on the preview on then the clips play back properly and completely. I also noticed the wave files playback thru the Kona 3 card with a slap echo. I can turn change the settings on the M100 audio output w/in M100 & it then plays back OK but returns in a few minutes. Very odd. I’m gonna try exporting these programs into FC7 & see how they play and sound soon.
