Activity Forums Apple Final Cut Pro Legacy Old Timey Fade Out
  • Old Timey Fade Out
    Posted by Seth Siegler on June 28, 2008 at 6:17 pm
    Hey everyone,
    I’m running fcp 5.1.4 and working with a 60i hdv sequence.
    I’m looking to do one of those old fashioned fade outs where the corners of the screen fade to black and end up moving towards the center in a circular form. Kind of like an iris transition but backwards. ( I tried reversing an iris transition but that didn’t do the trick)
    It’s kind of like the way that old tv shows used to fade out like I love Lucy and even Loony Tunes.
    I can’t find anything in my stock FCP or even in Motion. Can I get a plug in or something for that?
    Thanks for any help you guys can come up with!
    –Seth
    Todd Kramer replied 17 years ago 6 Members · 7 Replies
  • 7 Replies
  • Tom Wolsky
    June 28, 2008 at 8:10 pm
    What you describe is exactly what an oval iris is. What’s not working for you? If you reverse the iris it should do what you want. What happens when you do that?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Bill Dewald
    June 28, 2008 at 9:04 pm
    Use the oval Mask Shape filter, in the Matte section of the video filters. Keyframe the center and scale as needed.
    Is that what you mean? Like the the Bugs Bunny cartoons?
  • Seth Siegler
    June 29, 2008 at 3:11 am
    Thanks for the tips guys,
    It’s still not quite what I’m looking for though.
    The standard Oval Iris is perfect for the beginning of the clip. It Starts with a black frame and “opens” the screen from a circle in the middle of the frame.
    At the end is where the problem is. When I reverse the Iris, it starts with a black frame and ends with video. Same as the beginning of the clip only backwards. I’m looking to start with video in the frame, and have the iris circle close in from the edges of the screen and end with a black frame.
    Thanks again everyone!
  • Andy Mees
    June 29, 2008 at 4:09 am
    double click the effect as applied in the timeline. there is a small button in the effect controls, directly to the right of the Start and End percentage sliders … that button toggles the”direction” of the effect.
    press it then review the applied effect in the canvas. is that what you want?
  • Nick Meyers
    June 29, 2008 at 12:52 pm
    one thing the old time iris out did was to close part way,
    stop on something in the frame, (a person or face)
    then close all the way down.
    for this, i’d recommend the free Marcus Herick “Vignette” plugin.
    it’s a cool plugin to have anyway,
    and you can keyframe grat iris moves with it.
    https://www.haiku.com.au/2005/08/final-cut-pro-plug-ins.html
    nick
  • Seth Siegler
    June 30, 2008 at 5:26 pm
    Well I learn something new about Final Cut every day!
    That button to the right of the start/end percentages is exactly what I was looking for.
    When I said I “reversed the iris”, I should’ve been more descriptive. What I did was simply switch the 100% and 0%.
    All I needed to do to get the desired effect was to hit that button.
    Thanks a million for all those tips guys!
    –Seth
  • Todd Kramer
    August 17, 2009 at 9:05 pm
    I see this has come a couple of times but I couldn’t find that button either. Thanks Seth!
