Activity › Forums › Apple Final Cut Pro Legacy › Old projects won’t render
  • Old projects won’t render
    Posted by Chris Poisson on August 23, 2005 at 1:25 pm
    Yesterday I had to open up some 4.5 projects in 5.0.2, and some video clips needed rendering, but it would not let me do it. The render bar came on for a second and just went off. No warning alert or anything. Happened on at least two different projects.
    Anyone else seen this?
    Aaron Neitz replied 21 years, 1 month ago 3 Members · 3 Replies
  • David Bogie
    August 23, 2005 at 1:39 pm
    I’ve see this, too.
    Did you get the warning that the project will update and to save into the new format?
    I think you must do this in order to render to the new engine. You should get a box that says you have three choices for the render quality when you update the media files.
    I’d make a copy of your 4.5 project files at the Finder level before updating them.
    Hope you get it fixed, Chris, stuff like this usually doesn’t stop you.
    bogiesan
  • Chris Poisson
    August 23, 2005 at 3:23 pm
    Hey David,
    Yes, got the warning and let it update the file. I”m not sure what copying to the finder level would do, but I will try that later today. I’m also gonna try opening a new 5.0.2 project and import the old into it and see what happens. Thanks for the quick response!
  • Aaron Neitz
    August 23, 2005 at 4:00 pm
    I had this happen last week…. seems like I check every option in Render All, and then took off In/Out, and then selected “Both” from the Render drop down menu. Keyboard shortcuts weren’t doing it.
