Activity Forums DaVinci Resolve Old Project not opening but new project does.
  • Old Project not opening but new project does.
    Posted by Adam Berch on March 13, 2018 at 4:25 pm
    I’m working with Davinci 14 Free
    I’ve been working on a project for the past week, including this morning.
    I went to open it up again, and when it gets to the screen where I can pick the project I’m working on, it crashes and does not open. It goes straight back to my desktop.
    When I open it again and press New Project, it opens fine.
    How can I get the project I’m working on to open again?
    Thanks in advance
    Adam Berch replied 8 years, 6 months ago 3 Members · 3 Replies
  • Marc Wielage
    March 14, 2018 at 2:31 am
    Shot in the dark: what if you launch Resolve, stay in the Project Manager page, then right-click and export the bad project in question. This will create a DRP file you can temporarily keep on the desktop.
    Now right-click within the Project Manager screen, choose import, and select that file. It’s possible that the new imported file (which you should give a new name) may be able to work. If it doesn’t, contact BMD Support and send the file to them and see if they can recover it.
    I find it’s always a good habit to save a backup of your current project just in case there’s a problem. And keep it on an external drive outside your current project database. That way, even if the drive goes down, the project itself is covered.
  • Michael Gissing
    March 14, 2018 at 3:45 am
    I’ve had the odd issue with older versions of a crash when opening a big project straight after opening the software. Try opening a small project or even a new one, then open the project you want. In other words it’s not the first project you open after starting. That worked for me when it happened occasionally.
  • Adam Berch
    March 14, 2018 at 12:59 pm
    Thank for the ideas.
    I did manage to fix the problem.
    I opened up Resolve and when I got to the project window, I right clicked on the one that wouldn’t open and click on Read only.
    The project opened, I saved it as another name, then deleted the one that wouldn’t open. It works fine now.
