Activity › Forums › Media 100 › Old Media 100 Programs – Wrong Audio Rate and Resolution – Convert?
  • Old Media 100 Programs – Wrong Audio Rate and Resolution – Convert?
    Posted by Michael J c on April 10, 2006 at 10:17 pm
    I hope this isn’t a double post… (I don’t know where the original question went).
    Anyway… I need to take an old M100i program (640×480 and 44116Hz) which is completey offline and manually replace each edit with new media (720×486 and 44100) that is already digitized into the M100HD system.
    I thought I could do an edl out, then back in, but that remaps the audio tracks.
    I can export an XML file, but that doesn’t re-import into the M100HD w/o an error.
    I don’t see any way to simply get this program to re-conform to a new resolution and audio frequency.
    Any ideas?
    (I don’t want to go back to the tapes and re-dig using command/option/control because all the media I need is already on the system). So how would I do this?
    Michael J c replied 20 years, 5 months ago 2 Members · 3 Replies
  • Floh Peters
    April 11, 2006 at 6:02 am
    [Michael C.] “Anyway… I need to take an old M100i program (640×480 and 44116Hz) which is completey offline and manually replace each edit with new media (720×486 and 44100) that is already digitized into the M100HD system.”
    Actually I would recommend to always work in 48kHz, since all digital decks (DigiBeta, DVCPro,…) record at 48kHz.
    [Michael C.] “(I don’t want to go back to the tapes and re-dig using command/option/control because all the media I need is already on the system). So how would I do this?”
    I
  • Michael J c
    April 11, 2006 at 6:11 pm
    Good idea… I’ll try that!
  • Michael J c
    April 11, 2006 at 6:27 pm
    That worked flawlessly… Thnanks Floh!
