Activity Forums Apple Final Cut Pro Legacy Old Final Cut Pro set up
  • Old Final Cut Pro set up
    Posted by Scott Sudbury on June 11, 2010 at 6:25 am
    Hello,
    Need help on how to perhaps upgrade a lighly used older mac to edit low end feature films on.
    My question is should I update some hardware and/or software to use it or try and use as is?
    It the G5 and is running 10.3.9
    Final Cut Pro HD
    and a duel 2 ghz (mac) processors and 3.5 g of
    ddr.
    The camera is a sony ex-1.
    Rafael Amador replied 16 years, 2 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    June 11, 2010 at 3:49 pm
    You’d be miles ahead with an intel based mac so you could run FCS (2009) and FCP 7… Miles and miles. For starters, it’s inexpensive, and it supports what that camera shoots. I can’t recall if FCP 6 did, but if it does, you need to at least upgrade to that. FCP HD won’t work with the XDCAM files at all.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Rafael Amador
    June 11, 2010 at 3:55 pm
    Right.
    Leopard and FCS2 will be OK to edit XDCAM in your G5.
    rafael
    http://www.nagavideo.com
