Activity Forums Apple Final Cut Pro Legacy Old fashioned problem. Converting 486 to 480 for FCP
  • Old fashioned problem. Converting 486 to 480 for FCP
    Posted by Ian Venables on May 16, 2013 at 5:25 pm
    Hey There,
    A client recently took delivery of an AJA Ki-Pro to replace their aging DVCam deck. They are running into issues however with the files ut is exporting. The AJA records the ProRes files as 720 x 486, but all of their legacy footage (and footage from cameras not recording to the AJA) is 720 x 480. When the footage is converted in Compressor it seems to be a bit “jaggie” compared to the original source material.
    I know this is a problem from about 6 years ago, but any help for an SD editor in an HD world would be very much appreciated!
    Ian Venables
    Rafael Amador replied 13 years, 3 months ago 4 Members · 3 Replies
  • Steve Eisen
    May 16, 2013 at 7:13 pm
    What are you converting to in Compressor?
    Is your sequence ProRes or DV-NTSC?
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Nick Meyers
    May 17, 2013 at 2:11 am
    I’m not totally across the 480 / 486 issues,
    but in compressor you do have the option of PADDING to the source ratio
    look in the geometry pane of the inspector.
    this will ad 6 lines of black spread across top & bottom, and there will be no re-sizing on the original image
    nick
  • Rafael Amador
    May 17, 2013 at 2:19 am
    [Ian Venables] “The AJA records the ProRes files as 720 x 486, but all of their legacy footage (and footage from cameras not recording to the AJA) is 720 x 480. When the footage is converted in Compressor it seems to be a bit “jaggie” compared to the original source material.”
    No need to convert nothing.
    Drop the 720×486 stuff on the 720×480 sequence.
    FC knows how to manage the 6 lines cropping.
    rafael
