Activity Forums Cinematography Old camcorder with dual lenses??? anyone remember
  • Old camcorder with dual lenses??? anyone remember
    Posted by Scott Bush on April 16, 2009 at 3:12 pm
    Ok sorry if this is the wrong place for this, and sorry since it is just a silly nostalgia question BUT…
    Does anyone out there remember a unique 2-lens camcorder (for the consumer market I think) that had the dual lenses mounted one above the other? I believe one was a standard zoom lens while the other was a wide angle fixed lens. The cool thing was you could cut or dissolve between them on-the-fly, making for what was (as a youngster just learning) some really neat effects for the time. This would have been the early 90s most likely… from what I recall it was a full-size VHS shoulder cam… but I could be way off on that. I also want to say it was either sharp or panasonic that made it but again, the only thing I truly remember is the dual lens system…
    Anyone seen/remember this?
    Thanks.
    scott
    Frank Nave replied 11 years, 10 months ago 6 Members · 16 Replies
  • 16 Replies
  • Matthew Romanis
    April 19, 2009 at 1:13 am
    I remember a thing called the “Duo-Cam” from Samsung. It had a lens for the video CCD above a lens for the stills CCD.
    My old Super 8 film camera has a 3 lens barrel that rotates. Very retro.
  • Scott Bush
    April 19, 2009 at 5:58 pm
    Nah, Matthew, I remember that Samsung thing, too – was actually fairly recent. The one I’m talking about would have been older than that early or mid 90s – I doubt it even took stills – and would have been pre-digital. BOTH lenses were for video.
  • Matthew Romanis
    April 19, 2009 at 10:45 pm
  • Matthew Romanis
    April 19, 2009 at 10:58 pm
    I think I remember something from when I was a kid. My father bought his 1st video camera in 1984 which was a JVC camera head that looked like a Super 8 camera, but had a VHS portapack recorder (I had to carry it and there wasn’t much “Portable” about it!!).
    I can remember another version of the camera that had two lens’s on a rotating barrel, I think one was a mid range zoom, the other a longer range zoom.
  • Scott Bush
    April 20, 2009 at 2:42 am
    Heh, no not that either – not THAT old. It didn’t rotate – you could switch between them on the fly, while recording – dissolve or cut between them. One was fixed, wide – the other a zoom lens. Was a camcorder – no shoulder pack or anything needed.
    Thanks for the link, though. Pretty cool.
  • Andrew Haley
    April 27, 2009 at 6:28 pm
    When I was in High-School (88-92) the head of the Math Dept had one of these. He had a small businees creating math teaching videos, and there were a couple times he taped a musical or two with it (I was in the Choir). I was just at the begining of my interest in video and film production, and for the life of me, can’t remember any specifics of the camera, and I remember the results were realitivly poor, with problems lineing up the shots between the two lenses ect. All that said… the end result was better than many other single camera jobs I’d seen.
    So to answer your question, yes I remember/saw one of those, but as far as a make and model…. sorry, don’t know, although for some reason I want to guess Panasonic…
    –Andrew
  • Scott Bush
    April 27, 2009 at 7:03 pm
    Cool! I was starting to wonder if I’d dreamed it! I remember when I was trying to buy my first camera (consumer level) I had my eye on it – but was convinced otherwise after a demo, mostly because of picture quality. It was at the end of its run and much better lenses and CCDs were available in smaller packages and I went with a hi-8 — but I remember being very intrigued by the possibilities. It wasn’t so easy to create a dissolve with consumer equipment in those days, especially not without significant quality loss. Thanks for responding!
    Scott
  • Eugene Kang
    May 14, 2009 at 2:34 pm
    A friend gave one to me a long time ago… I remember seeing it in shops when I was a kid too… it was really expensive then.
    From memory it was a Sharp model, had a spring-loaded lenscap that was attached to the body, and the first (or one of the first) color LCD viewfinders (with pretty awful resolution). It also recorded audio in stereo, and had RCA outputs on the side underneath a flap. One lens was wide, one was zoom. It wasn’t a shoulder-mount camera though, it was a handycam-style camera.
    This is the only photo I can find of it… is it the one you had in mind?
    https://www.moma.org/interactives/exhibitions/1995/mutantmaterials/plasticgifs/16sakata.gif
  • Scott Bush
    May 14, 2009 at 3:12 pm
    Wow eugene! That may be it… I still remember a larger version of it, but that’s the right idea and the lens mount is totally right, so maybe my mind is just playing tricks on me. I ended up buying an 8mm camera after they compared the picture quality side by side in the store, so it was definitely during the handycam era – but it also wasn’t any more expensive than the one I bought, so it may have been an older model. Either way, that’s definitely the same lens system! How did you find that picture? I’ve been searching for ages! Thanks!!!!
  • Eugene Kang
    May 15, 2009 at 2:22 am
    It took a bit of browsing through google images. 🙂
    If I didn’t throw it out a few years ago, I would be able to give you the model number and some clearer photos!
    I don’t remember other cameras with two lenses, but I never looked around and I was really young at that time too. That one just stood out because it had two lens barrels. It was either Video8 or Hi8.
    I remember the wide angle sensor being pretty soft and crappy.
    Kodak’s V570 reminded me of it… 23mm in a compact is pretty cool!
