Activity Forums Adobe After Effects Old BlackMagic Extreme with After effects CS5
  • Old BlackMagic Extreme with After effects CS5
    Posted by David Peled on March 29, 2011 at 12:13 am
    I’m trying to hook up an old BMC extreme PCI-X (Not PCI-e) on a PC machine based on Intel i7 960, Asus P6X58D Premium, and a QudroFX1800 graphic card, running Windows 7 64bit Ultimate edition. the driver installed just fine with no spacial issues, I can access the control panel, and it recognize the card by its Name. When I switch the input from Composite to component I see the monitor responding accordingly. so far so good, but when i’m trying to view an after effects CS5 composition via the card, all I get is Black (not Blank) signal no matter what kind of setup i choose from the adobe preferences menu. Same goes to Premiere CS5. I tried several file formats, from DV PAL, to Blackmagic 10/8 bit YUV/RGB.
    I tried with great success to view any composition via the adobe built-in DV out put module.
    All software/drivers are updated to their latests versions.
    I’ve tried 2 cards like that, with same results.
    Is there a compatibility issue here? or, Am I doing something wrong?
    Thnaks for your time.
    David Peled.
    David Peled replied 15 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
