Activity › Forums › Adobe After Effects Expressions › Old 8mm Flicker
Old 8mm Flicker
Posted by Dan Stevers on August 27, 2006 at 6:28 pmdoes anyone have an expression for the flickering opacity of an old 8mm film. I want my movie to feel old and i think it will help.
Dan Stevers replied 20 years ago 4 Members · 4 Replies -
Erik Pontius
August 27, 2006 at 9:39 pmYou might get some tips in Aharon’s “old TV screen” tutorial. If I recall he does an expression to mimic the tv scan retrace flicker…perhaps it could be modified to get the effect you’re looking for…
https://forums.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=2&page=https://www.creativecow.net/articles/rabinowitz_aharon/old_tv/index.htmlerik
Chris Smith
August 28, 2006 at 1:36 amalso search the archives for “8mm” and the like. It’s been talked about a lot. I know I personaly have posted my 8mm recip
Mark
August 28, 2006 at 10:40 amI use the wiggler for this one. I put a black solid layer on the top of all layers, then add two opacity keyframes, one at the beginning, one at the end…both are set to around 30% opacity. I then apply the wiggler. I usually set the amount to around 20 and the frequency to 24. You can also play around with transfer modes, such as multiply. I find also repeating the above but with a slight blur can help acheive the look.
Regards
Mark
