Activity Forums Apple Final Cut Pro Legacy Ok..I know I am doing something wrong but not really sure as to where to look…want to get footage from JVC GR-HD1 ontoo my intel iMac
  • Ok..I know I am doing something wrong but not really sure as to where to look…want to get footage from JVC GR-HD1 ontoo my intel iMac
    Posted by Todd George on June 25, 2007 at 6:33 pm
    Hello all
    I am using a 17inch Imac with a 1.83 GHz Intel Core Duo processor with 1Gig or ram running OS 10.4.9
    I have FCP5.1.4 running
    my boss bought the department a GR-HD1 last week
    the mandate was shoot some video with it and tell me what you think
    well I admit I am not one to read every instruction in the manual and I opted for the it’ll all work out in the end school of thought
    I literally took the camera out of the box, let the battery charge and went outside to shoot some footae….
    and I hoped that once I pluged the deck in via the iLink port all would be well
    not so
    the deck is recognized but I get no preview during log and capture and I cannot capture
    I did a search of the cow archives and stumbled across a post from Jan 07 which basically suggested looking into Quicktimes Mpeg 2 playback plugin
    I have QTpro o this machine..is addidtional software needed
    and I am sure there must be an easy setup configuration I need to either create or select
    if anyone has any suggestions that would be wonderful
    just in case I am not making myself clear here is a recap
    I have an intel Imac
    running os 10.4.9
    I have fcp5.1.4
    I have a JVC GR-HD1 camera
    I shot video on the camera using the dv setting
    I brought the camera back to the imac
    connect the two via firewire
    I can open FCP and do log and capture
    I get preview disabled
    but I have device control
    I cannot capture video
    I need to know if I csn capture video using this camera and my current fcp setup or if I need additional software
    thank you all in advance
    Todd George
    Todd George
    Instructional Media Services
    John Carroll University
    University Heights, OH 44118
    Todd George replied 19 years, 2 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    June 25, 2007 at 8:41 pm
    I think that camera’s device control setting needs to be set to HDV FireWire Basic for it to work right.. try that and post back if it doesn’t work OK.
    Jerry
  • Todd George
    July 9, 2007 at 7:20 pm
    Hello all
    ok here is what I ended up doing
    shot video in dv/sd format
    ended up changing the cature preset to HDV Apple Intermediate Codec : which TRANSCOES the HDV into an sd readable format (at least that is what I think is happening under the hood)
    also used HDV Firewire Basic for Device Control
    the log and capture window is VERY different from the old L&C from sd video …in and out point cans be set but it seems to like to go straight into a capture now mode
    ALSO I had to set the camera’s iLink output button to Mpeg as opossed to dv (not an intuitive thing but after trial an error)
    another word of caution…playback during L&C lags behind and you can NOTICE IT don’t panic it all seems to have worked out fine in the end
    data rates and file sizes are higer
    take care and thanks to all who helped
