Activity › Forums › Apple Final Cut Pro Legacy › ok, setting sizes for boardcast widescreen???
  • ok, setting sizes for boardcast widescreen???
    Posted by Delano Bryant on October 9, 2007 at 2:30 pm
    I exported my 1440×1080 timeline using QT. I imported these files into DVD studio pro. I played the DVD on my DVD player and about 10% of my images where off the sides….
    What timeline settings for editing in HD to output highest quality for SD broadcast widescreen?
    Is that the color red you want to use?
    Delano Bryant replied 18 years, 12 months ago 2 Members · 3 Replies
  • Delano Bryant
    October 9, 2007 at 3:05 pm
    hmmm checking my settings on DVD.. it looks as if I had it on 4:3. If I change that to 16:9 to I do letterbox, pan scan? or what?
  • Michael Sacci
    October 9, 2007 at 3:31 pm
    Does your image look correct? If so this could be you losing the normal action safe which is 10% all around.
    So can you give information, what settings did you use in DVDSP to m2v, 16:9? 4:3?
    The question is not what timeline settings but what compressor settings give you the best.
    I never like DVDSP go my encoding, I don’t like the workflow and you lose control plus you are stuck with PCM audio.
    I almost always export to Compressor from my timeline, this will give you the best encodes, especially when coming from a HDV timeline.
    Make a new preset w/ a CBR setting as high as you can (but never do over 7Mbps)
    Set the Encoder tab Aspect to “16:9”, Field Dominance to “Top First”
    Then under Quality Mode to “One Pass CBR” Average 6.5 (if that fits
    Motion Estimation doesn’t matter on CBR
    SAVE
    Then for ac3 settings for the audio default with a couple of changes is good.
    Change 1 set Dialog Normalization to -31dB, this turns it off
    Change 2 Under processing tab set compress preset to “None”
    This will give you hands down the best encode. But do a short test since it ties up your FCP while doing the encode. A 5 min section of your timeline would give you a good feel for the end result.
    If you tell me the total length of all you material on the dvd I can give you an exact bitrate for the video or you can find bitrate calculator online.
  • Delano Bryant
    October 9, 2007 at 4:15 pm
    if my timeline is to be sent out for broadcast. AND a DVD made I want to edit on a 1440x1080i timeline. then export that for SD broadcast and for DVD. For the DVD I’ll use the settings you suggested.
    My question is also, is that the best timeline settings for HDV footage from HDV cameras?
