Activity Forums Avid Media Composer OHCI port?
  • OHCI port?
    Posted by Matt Babinec on June 8, 2005 at 12:16 am
    hi, every time i open a project in avid xpress, or create a new project, i get a warning message that says
    “the port “OHCI” is busy and cannot be used for deck control”
    what does this mean, and how can i fix this problem?
    thanks!
    Dean Speller replied 17 years, 3 months ago 4 Members · 6 Replies
  • Michael Phillips
    June 8, 2005 at 11:30 am
    The FiWire connection is blocked or being used by another device…. is there something else on the same bus? Check the device manager if on XP.
  • Roc Barbanica
    June 8, 2005 at 4:34 pm
    You have two configs trying to use the port-
    Delete one of the decks.
  • Matt Babinec
    June 8, 2005 at 5:24 pm
    well, i removed my firewire card, and i still get the same error….
    should i try installing it again in a diffrent PCI slot?
  • Matt Babinec
    June 8, 2005 at 9:06 pm
    alright,
    i took the firewire card out and put it in a diffrent PCI slot, and i still get the same message in avid. how can i fix this problem, i have a rather important project coming up tomorrow.
    thanks!
  • Roc Barbanica
    June 8, 2005 at 10:04 pm
    I suggest you check your port allocation in the deck settings…
  • Dean Speller
    June 18, 2009 at 11:50 am
    I also was experiencing this problem.
    I resolved it by going to ‘deck configuration’ under ther settings tab and removing the duplicated firewire setting.
    All now works fine 🙂
