Activity › Forums › Adobe After Effects Expressions › Oh please! I need to change result values, 82-100 to be 0-400, simple math isn’t enough
  • Oh please! I need to change result values, 82-100 to be 0-400, simple math isn’t enough
    Posted by Kris Alvarado on April 15, 2015 at 9:43 pm
    Ah I am dying, I’ve been looking all day and my eye are about to fall out. Any help and I would really appreciate it.
    I want to make it when I scale up a precomp it’s linked to a matching drop shadow. Fake 3D basically
    So my precomp scales from 82-100 and my drop shadow needs to go from 0-400.
    I added transform.scale[0] in the drop shadow size, so now it goes from 82-100. I’ve racked my brain multiply and dividing with -81*100 but nothing works, I need to go form 0 or maybe 1.
    oh please help, I’m a total noob and at your mercy!
    transform.scale[0]-81*100
    Kevin Camp replied 11 years, 5 months ago 3 Members · 6 Replies
  • Kevin Camp
    April 17, 2015 at 7:01 pm
    try this:
    linear( scale[0], 81, 100, 0, 400 )
    [edit]
    I see dan had responded to your second post… doh!
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Kris Alvarado
    April 17, 2015 at 7:06 pm
    Thank you! Yes worked perfectly!
    You guys rock!
    Also how do you write it if your connecting to another comp? Right now I have:
    thisComp.layer(“Brick_Icon”).linear(transform.scale[0],100,83.3,100,0);
    I don’t get an error but it also doesnt work :/ This is for the opacity of a type layer to be linked to scale as well
  • Dan Ebberts
    April 17, 2015 at 7:37 pm
    Try it this way:
    s = thisComp.layer(“Brick_Icon”).transform.scale[0];
    linear(s,82,100,0,400)
    Dan
  • Kris Alvarado
    April 17, 2015 at 7:46 pm
    Yup, worked perfectly!
    Thank you!
    If you don’t mind me asking, what is the “s” that made it all work? I tried researching instead of bothering you guys again I can’t find it, I wanna really learn
  • Dan Ebberts
    April 17, 2015 at 7:59 pm
    s is just a variable, a temporary location to store the x scale value.
    Dan
  • Kevin Camp
    April 17, 2015 at 8:03 pm
    by signing the value that is in another comp to ‘s’ it makes it easier to update
    you could have done it like this:
    linear( thisComp.layer("Brick_Icon").transform.scale[0], 82, 100, 0, 400 )
    but by defining ‘s’ as the value in another comp, you could more easily change to a value in another comp by changing ‘s’.
    — note, you could name the variable anything alpha-numerical, as long as it doesn’t start with a number, you could name the variable ‘scale1’ for example.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
