Activity Forums Adobe After Effects Oh crap! Project overwritten by save comp as project script!
  • Oh crap! Project overwritten by save comp as project script!
    Posted by George Goodman on December 10, 2013 at 4:16 pm
    I’ve just used the save composition as project script, but rather than creating a new project, it overwrote my entire project file. All I did was create a new comp, put the object I wanted in that comp, had it selected in the project panel, and clicked save comp. At first it errored, then it said complete. Low and behold, project overwritten.
    What’s worse – I’m not sure when it happened, but apparently my autosave was turned off, so I have no previous versions of the project.
    Anyone know of any miracles that can restore a previous version of my project? Pretty sure I’m screwed. I don’t have time machine.
    George
    Mike Abbott replied 12 years, 9 months ago 4 Members · 6 Replies
  • Mathew Fuller
    December 10, 2013 at 5:25 pm
    If its still open you can undo back as far as possible.
    You can avoid this in the future by making your saves iterative. Then you can always go back.
    In the future. .. never have only one copy of an AE project.
    My Work:
    https://www.morecompletefx.com
  • Walter Soyka
    December 10, 2013 at 5:57 pm
    [mathew fuller] “You can avoid this in the future by making your saves iterative. Then you can always go back. In the future. .. never have only one copy of an AE project.”
    Such important advice.
    Mathew’s referring to Increment and Save (Ctrl+Shift+Alt+S on Windows, Cmd+Shift+Opt+S on Macs). This will add/increment a number to your current project file name, leaving previous versions on the disk. I do this at least every couple hours to protect previous work in case something goes sideways.
    If you happen to be using Dropbox, you should be able to restore an older version of the project file. Otherwise, it’s possible you might get lucky with an undelete utility, but good practice upfront like Mathew describes is best.
    Walter Soyka
  • George Goodman
    December 10, 2013 at 8:50 pm
    Undo didn’t work.
    Fortunately I did have two copies…kinda – this was version 2.
    Cost me about 10 hrs.
    Pretty upset at the script though. Going forward I will always make duplicate versions of projects before attempting to run it. I’ve also, of course, enabled autosave. Must have disabled itself during an update – also unfortunate. I’ll look in to iterative saves.
    G
  • Mike Abbott
    December 11, 2013 at 2:50 pm
    Hi George,
    I just happened to stumble over this thread when I was here posting something else.
    As it happens – I’ve just had the same experience of ‘save comp as project’ overwriting a file.
    I think it was a due to some comp names I was processing having an illegal Windows file name character – ie any one of: < > : ” / | ? *
    I think I had a “/” in a comp name.
    I’m going to try and run a brief test today and report back to the author.
    Mike
  • George Goodman
    December 11, 2013 at 5:20 pm
    Yes Mike, this is exactly what happened to me. I was suspect that is what caused it – but now you’ve totally confirmed it. I included a “/” in the name as well.
  • Mike Abbott
    December 11, 2013 at 5:50 pm
    George – and others:
    I’ve been in touch with Seb, the script author, and sent a test file – so he’s aware of the issue. Hopefully a fix will follow.
