Activity › Forums › Adobe After Effects Expressions › Oh… and… Using expression to offset time-remap from a slider
  • Oh… and… Using expression to offset time-remap from a slider
    Posted by Jim Lefevre on August 31, 2011 at 9:44 am
    Following on from my previous post about setting up a ‘Tree’ with a load of leaves going through different seasons…
    I have a ‘tree’ with a lot of leaves (LEAF.COMP). Within this comp is animation that takes the leaf through SPRING SUMMER AUTUMN and WINTER.
    I have currently laid out the leaves around the tree and want to offset groups of them so that the animation is staggered.
    I have a layer with an expression slider (SEASONS SLIDER).
    With this I want to the LEAF.COMP to take the slider value as its time-remap value but also be able to offset it it to different degrees.
    I will have about 5 groups of leaves each with differing offset values (groupA LEAF.COMP offset by 4 frames, groupB LEAF.COMP offset by 7 frames etc…).
    The expression which I am using is below
    thisComp.layer("SEASONS SLIDER").effect("Slider Control")("Slider").valueAtTime(time)
    BUT (even without any offset) when the SEASON SLIDER is a certain value it seems to be
    SEASON SLIDER LEAF.COMP time-remap value
    10 250
    so I am dividing it by 25
    thisComp.layer("SEASONS SLIDER").effect("Slider Control")("Slider").valueAtTime(time)/25
    However I am having a stupid mental block about offsetting it as
    thisComp.layer("SEASONS SLIDER").effect("Slider Control")("Slider").valueAtTime(time)/25-10
    obviously doesn’t work and
    thisComp.layer("SEASONS SLIDER").effect("Slider Control")("Slider").(valueAtTime(time)/25)-10
    (adding brackets around the valueAtTime(time)/25 bit) gives me an error…
    Can anyone advise me on how to offset this!
    http://www.jimlefevre.com
    Dan Ebberts replied 15 years, 1 month ago 2 Members · 1 Reply
  • Dan Ebberts
    August 31, 2011 at 6:38 pm
    I’m not sure exactly what you’re doing, but it looks like you may want your slider value to be frames, but time remapping expects seconds. So you probably need a conversion like this:
    f = thisComp.layer(“SEASONS SLIDER”).effect(“Slider Control”)(“Slider”);
    offset = -10; // offset in frames
    t = framesToTime(f+offset); // time in seconds
    Dan
