Activity Forums Adobe After Effects offsset/follow movement blur
  • offsset/follow movement blur
    Posted by Susan Lan on April 28, 2016 at 12:05 pm
    This fx has done with offsset or with follow expression? It’s only layer movement (of the girl) BUT it seems but motion blur especil, that is offset or what?
    Minute 0:40- to 0:41of this:
    https://www.youtube.com/watch?v=xZUBgq-zlww
    Walter Soyka replied 10 years, 4 months ago 2 Members · 5 Replies
  • Walter Soyka
    April 28, 2016 at 1:42 pm
    This looks a swish pan transition between two clips (or two instances of the same clip).
    Red Giant Universe (among others) has one:
    https://www.redgiant.com/universe-tools/transitions/
    You can build your own by turning on motion blur and pushing one layer off while pushing another on. You may need to crank up the motion blur settings to get the effect you’re looking for.
    You could also use Offset and CC Force Motion Blur to do this within a single shot.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Susan Lan
    April 28, 2016 at 4:42 pm
    Thnaks Walter! And the transitions in the “Universe” pack that does that is how is called? “swish pan”? thanks
  • Susan Lan
    April 28, 2016 at 4:49 pm
    Ah, sorry, i just see it in the link you give me, is called “swish pan”, and the with that transition will obtain the same efeect that in trhe video, or I mkust do something else? Thanks a lot
  • Susan Lan
    April 28, 2016 at 5:33 pm
    at minute 0:39 is also used the “swish pan” transition? (I mean , when the girl is “zoom” (o how that’s called)
    or it’s only to make the layer move in Z space into the camera, with motion blur activated?
  • Walter Soyka
    April 29, 2016 at 2:56 pm
    [Susan Lan] “at minute 0:39 is also used the “swish pan” transition? (I mean , when the girl is “zoom” (o how that’s called) or it’s only to make the layer move in Z space into the camera, with motion blur activated?”
    That is not a swish pan transition; swish pans are named for the camera technique where a camera turns quickly.
    The approach you outlined above should work nicely.
    Walter Soyka
