Activity › Forums › Adobe After Effects › Offsetting the video while not moving the mask
  • Offsetting the video while not moving the mask
    Posted by Tero Ahlfors on January 10, 2012 at 3:46 am
    I feel really dumb right now. I haven’t been using AE for a while and can’t figure this out. I’ve been using this technique where you duplicate a layer and make a mask on eg. a wire on a sky and offset the video so I’m getting clean sky on the part I’ve masked. iQ has a DVE effect where you can move only the video or the matte or both. How can I offset the video while keeping the mask in the same place? If I change the position of the layer the mask moves with it.
    Walter Soyka replied 14 years, 8 months ago 3 Members · 5 Replies
  • Ben G unguren
    January 10, 2012 at 5:55 am
    You are moving with the selection (v) tool; try repositioning the layer’s time using the anchor-point selection (y) tool. As long as none of your layers are selected, the timing of the footage will change without moving any of the key frames.
    Other methods:
    – Use time remapping on your layer, then select both remap key frames (start and finish) and move those around as needed.
    – Pre-comp your layer, choosing the option to keep all settings in your current composition. Then go into the precomp and slide the layer around to your heart’s delight!
    – The clone tool (you find it as a part of the brush tool options) has a time offset feature, but of course it uses cloning instead of masks.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Tero Ahlfors
    January 10, 2012 at 6:22 am
    I don’t want to offset the time, just the position. Precomping sounds like a solution though it’s not as WYSIWYG I’d like. I’ll try that out when I can. Thanks.
  • Tero Ahlfors
    January 10, 2012 at 8:30 am
    Precomping still moves the mask around.
  • Tero Ahlfors
    January 10, 2012 at 11:31 am
    I messed up. Precomp worked.
  • Walter Soyka
    January 12, 2012 at 2:06 am
    The After Effects render order [link] is METL: masks, effects, transforms, layer styles, so your mask will always be applied before your position animation (transform).
    I know you found a solution with precomping, but here’s another alternative: you could use the masked image as an alpha matte [link] above an unmasked copy of the layer. This will let you transform the layer however you like, then matte it according the mask from the duplicate (but non-animated) layer above.
    Walter Soyka
