Activity Forums Adobe After Effects Expressions Offsetting parented layers X and Y values calculation
  • Offsetting parented layers X and Y values calculation
    Posted by Katya Austin on September 17, 2013 at 10:48 pm
    Hello,
    When parenting multiple layers to a null, for example, and then offsetting their positions from the parent null, i use this expression:
    X = thisComp.layer("Parent Null").transform.position[0];
    Y = thisComp.layer("Parent Null").transform.position[1];
    [X -/+ 0, Y -/+ 0]
    and then spend bunch of time playing ‘guess the right X and Y values’ game, until parented layers are where i want them to be.
    My question is, is there a more efficient way of calculating offset values for X and Y, other than guessing how many pixels the layer is off?
    I know i could just adjust the anchor point values, but sometimes i need it to be in some specific place to be able to attach effects to it.
    thank you,
    -Katya
    Katya Austin replied 13 years ago 2 Members · 2 Replies
  • Dan Ebberts
    September 18, 2013 at 12:37 am
    When you parent a layer to a null, its position becomes the offset from the null. Maybe you just need to tie the x and y position values to slider controls.
    Dan
  • Katya Austin
    September 20, 2013 at 12:11 am
    I was thinking about sliders as well, but creating separate X and Y controller adds the same amount of time as guessing offset values. I was hoping for a ruler plugin (or script), like measure tool in illustrator and photoshop that would calculate X and Y offsets from original placing.
    thanks for your reply!
    -k
