Activity Forums Maxon Cinema 4D Offsetting keyframes in a mograph cloned sequence
  • Offsetting keyframes in a mograph cloned sequence
    Posted by Joey Campbell on April 11, 2013 at 4:44 pm
    Hi – I ‘ve got an animated flower which has been cloned.
    The cloner mode is set to object….the object is a sphere and the clones are attached to the surface of the sphere.
    The sphere is animated to warp and the cloned flowers move/sway with the sphere as it ‘wobbles’.
    My issue is that the flower itself has an animation (it unfolds/buds over 50 frames). At the moment all of the cloned flowers ‘bud’ at the same time. I’ve tried using a frame offset in a random effector and a plain effector but it makes no difference. What is the best way to offset the animated keyframes for each cloned flower so that I get some overlap in my ’emerging’ cluster of cloned flowers?
    Any help would be great.
    Joey Campbell replied 13 years, 4 months ago 3 Members · 3 Replies
  • Cassius Marques
    April 11, 2013 at 5:37 pm
    how much overlap do you need? and for how long?
    …Can’t you just duplicate the flower group a few times and offset the blooming keyframes?
  • Adam Trachtenberg
    April 11, 2013 at 6:14 pm
    Do you have the cloner’s “render instances” box checked? If so, uncheck it. It doesn’t work with animation offset.
  • Joey Campbell
    April 11, 2013 at 10:14 pm
    Thanks Cassius – that worked fine.
