Activity Forums Adobe Premiere Pro Offsetting audio by half a frame
  • Offsetting audio by half a frame
    Posted by Chris Johnston on March 24, 2010 at 6:27 pm
    I shoot a bi weekly cooking show that I generally use 2-3 camers for.
    I use a clap board to sync the 3 cameras in post, but frequently I find the audio for camera 2 or 3 off by a fraction of a frame.
    If you use audio from both (or all) cameras you get a slight delay that almost sounds like an echo.
    I guess my question is……
    I seem to remember seeing somewhere, a video that showed being able to move the audio track at a more precise amount than 1 frame???
    Say 1/4 frame or 1/2 frame????
    This post make sense?
    José Roitberg replied 13 years, 4 months ago 3 Members · 4 Replies
  • Vince Becquiot
    March 24, 2010 at 6:30 pm
    Change the menu setting on the right top side of the timeline to “Audio units”.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Chris Johnston
    March 24, 2010 at 9:42 pm
    Thanks Vince, I thought it would be something simple like that.
  • José Roitberg
    May 17, 2013 at 7:52 pm
    As an AVID an Vegas user I struggled with this issue, so simple in Vegas. But using [Show Audio Time Units] does not make you able to align clips by audio perfectly. You have also to use the [Slide Tool – U -] at tools menu. Regular or other cursors didn’t make it. With audio time units you will position the clip exactly synchronized in a flash, at any fraction of frame required. Without time units, this tool is useful as you can slide easily a frame at a time.
  • José Roitberg
    May 17, 2013 at 7:57 pm
    As an AVID an Vegas user I struggled with this issue, so simple in Vegas. But using [Show Audio Time Units] does not make you able to align clips by audio perfectly. You have also to use the [ALT + Slide Tool – U -] at tools menu. Regular or other cursors didn’t make it. With audio time units you will position the clip exactly synchronized in a flash, at any fraction of frame required. Without time units, this tool is useful as you can slide easily a frame at a time.
