Activity Forums Maxon Cinema 4D Offsetting a Cloner Grid sheet of images
  • Offsetting a Cloner Grid sheet of images
    Posted by Bert Brown on May 1, 2017 at 3:36 pm
    I have a cloner with a grid layout of 6x10x1 random textures (generated by a Multi Shader). I need it to cascade down like a waterfall and either constantly generate from the top or loop back around (like a spline offset or spline effector would).
    I can’t figure out how to do this while maintaining the 6 cloners across AND the randomness for each image for the entire grid.
    Any thoughts?
    Brian Jones replied 9 years, 4 months ago 2 Members · 3 Replies
  • Brian Jones
    May 1, 2017 at 5:16 pm
    how long does the sequence have to maintain?
    -There are probably more ways but the ones that come to mind are just make the cloner a lot taller in Y and use a Plain effector to move the clone group down over time but only have your 6×10 grid visible by using an effector with a Box Falloff to control seeing only the one group of clones. 11315_cascadingclones1.c4d.zip
    -or have 6 splines side by side, connect them into one spline with 6 segments and clone along them and just offset to get your cascade 11316_cascadingclones2.c4d.zip
    the splines one is easier but clones just pop inane disappear the invisible clones one can have the clones fade in/out depending on how the falloff is set up ( I suppose you could do that with the splines one with an effector to control visibility there too…)
  • Bert Brown
    May 1, 2017 at 5:20 pm
    These are both good approaches. I hadn’t considered the multiple spline ones. I’ll probably end up using that. Although both of these feel like a cheat, you know? I was thinking the solution was something with the Matrix, which I never fully understand.
    But thank you! One of these should work for sure.
  • Brian Jones
    May 1, 2017 at 5:37 pm
    well the Matrix is basically a cloner that produces points in space rather than clones (which clones/particles/etc can be attached to or generated from etc) so the same rules apply to my understanding.
    The other possibility is to have particles being generated (from 6 emitters (or one emitter using 6 points (perhaps a Matrix) as the origins)) – with no rotation and a life span which gives the right ‘drop’ before they disappear you could get something visually identical
