Activity › Forums › Adobe After Effects Expressions › Offset position on 900 layers
Posted by Gon Perdigao on June 11, 2016 at 5:51 pmHello, I have 900 layers that they animate from -5000Z axis to 0.
I want to offset them by 5 frames, is there a fast and quick way of doing this?
I remember that grey machine had a tutorial about this, but I can’t find it.Can anyone help me?
Cheers
Gon Perdigao replied 10 years, 3 months ago 2 Members · 4 Replies -
Dan Ebberts
June 11, 2016 at 6:04 pmIf you currently have them keyframed, you could add something like this to the position property:
delay = (index-1)*framesToTime(5);
valueAtTime(time-delay)Dan
Gon Perdigao
June 11, 2016 at 6:26 pmDan you are the best!!!!!
Thanks so much for this.
If I would and wanna add this expression to the animation // Inertial Bounce (moves settle into place after bouncing around a little)
n = 0;if (numKeys > 0){
n = nearestKey(time).index;
if (key(n).time > time){
n–;
if (n == 0){t = 0;
}else{t = time – key(n).time;
if (n > 0){
v = velocityAtTime(key(n).time – thisComp.frameDuration/10);
amp = .05;
freq = 4.0;decay = 2.0;
value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
}else{
value;
}How could I do it?
Cheers
Dan Ebberts
June 11, 2016 at 8:27 pmTry this:
myTime = time-delay;
n = 0;
if (numKeys > 0){
n = nearestKey(myTime).index;
if (key(n).time > myTime){
n--;
if (n == 0){
t = 0;
}else{
t = myTime - key(n).time;
if (n > 0){
v = velocityAtTime(key(n).time - thisComp.frameDuration/10);
amp = .05;
freq = 4.0;
decay = 2.0;
valueAtTime(myTime) + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
}else{
valueAtTime(myTime);
Dan
Gon Perdigao
June 14, 2016 at 8:47 amDan, Thank you so much for your help!
You just save my life.Cheers
