Activity Forums Adobe After Effects Offset Position AND TIME expression
  • Offset Position AND TIME expression
    Posted by Jennifer Arani on September 11, 2012 at 11:22 pm
    Hello Everyone,
    I am trying to create an expression that will help me animate 15 pages of a pdf. I have the keyframe set for page 1.
    I want the other pages to fall in but moved over a hair on both x and y and their movement spaced out as well.
    So I found a thread that KINDA helps, but it only solves 1/2 my problem:
    https://forums.creativecow.net/readpost/2/875415
    And I have a script ALOT like it:
    offset = -.5;
    p = thisComp.layer(“Page 1/ProtectorPlus.psd”);
    t = time + offset;
    p.position.valueAtTime(t);
    So – For TIME this is GREAT works like a charm. For position offset, no so much!
    I have some code I made up with my whole 6 hours of expression experience, so only laugh a little at how bad it is. This works for the spacing but not the time:
    offset = index – 1;
    xNum = thisComp.layer(“Page 1/ProtectorPlus.psd”).position[0];
    yNum = thisComp.layer(“Page 1/ProtectorPlus.psd”).position[1];
    zNum = thisComp.layer(“Page 1/ProtectorPlus.psd”).position[2];
    x = xNum – offset+100;
    y = yNum – offset+50;
    z = zNum;
    [x,y,z]
    How the Heck do I COMBINE the first code and the second?! So my papers space correctly over time?
    thanks
    Jennifer
    Jennifer Arani
    Kevin Camp replied 14 years ago 3 Members · 3 Replies
  • Cassius Marques
    September 12, 2012 at 1:17 pm
    I suck at expressions, but I’ll try to help.
    First you have two different values for the variable offset…You’ll need to rename one.
    Since your first expression already instances your posisiton you won’t need to do it again on the second one… so i’m gessing you’ll just need to give it the position offset you want.
    Try something like
    offset = -.5;
    t = time + offset;
    r = p.position.valueAtTime(t);
    noffset = index – 1;
    [r[0] – noffset+100, r[1] – noffset+50, r[2]]
    Give me some feedback of what you got.
  • Cassius Marques
    September 12, 2012 at 1:26 pm
    Thinking about it, this will probably work only for the first layer (page 2)…but I’ll wait for you to check it out.
  • Kevin Camp
    September 13, 2012 at 3:07 pm
    if cassius’s expression did not work, i think this is what you are looking for:
    Delay = .5; // value in seconds
    Offset = [100,50,0]; // offset position array [x,y,z]
    PreviousLayer = thisComp.layer(index-1); // this looks at the layer right above it
    PreviousLayer.position.valueAtTime(time – Delay) + Offset; // this puts it all together
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
