Activity Forums Maxon Cinema 4D Offset nulls to play at different times
  • Offset nulls to play at different times
    Posted by Mike Tosetto on September 23, 2013 at 6:04 am
    Hi guys
    I can’t believe I’m stumped on this.
    I have a null which holds a bunch of mograph objects that animate how I want them to.
    I’ve duped that null 2 times so I have three nulls holding the same animation.
    All I want to do is offset the timing of the nulls so one null plays, then 12 frames later then next null starts and so on.
    I’m sure this must be a simple thing but I just can’t work it out?
    If anyone can shed some light on this I’d really appreciate it. I’m sure it must be a simple thing.
    Cheers
    Mike
    miketosetto dot com
    Mike Tosetto replied 12 years, 12 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 24, 2013 at 12:03 am
    Use the offset animation feature in a step or shader effector.
  • Mike Tosetto
    September 24, 2013 at 11:49 am
    Thanks Adam. Ending up solving this using Legacy XRefs and offsetting the animation.
    Did the trick.
    miketosetto dot com
