Activity Forums Adobe After Effects Expressions Offset keyframes randomly
  • Offset keyframes randomly
    Posted by Hannes Paulsson on September 8, 2011 at 10:13 am
    Hi!
    I have a comp with 256 different precomps (made another thread about this project a few days ago).
    All of these comps needs to rotate on the y-axis to 180 degrees. The thing is I don’t want them all to rotate at the same time, it is supposed to look random. What I have done is to animate the rotation on all of the precomps at the same time, and what I’m looking for is an expression that I could add that would offset these animations randomly by about 10 frames. I cannot offset the comps them self in time, since they all contains an animation that needs to be sync.
    I think this should be quite simple, just a short expression on the rotation value?
    Dan Ebberts replied 3 years, 6 months ago 4 Members · 5 Replies
  • Dan Ebberts
    September 8, 2011 at 1:18 pm
    Try this:
    maxOffset = 10; // frames
    seedRandom(index,true);
    offset = framesToTime(random(maxOffset));
    valueAtTime(time-offset)
    Dan
  • Hannes Paulsson
    September 8, 2011 at 1:23 pm
    Awesome, works like a charm!
    Thanks again Dan!
  • Stuart Paciej
    April 1, 2020 at 2:03 pm
    Ancient post here but I just found it and wondered how you would make this behavior offset a loopOut expression?
    Adding it at the end just overrides the offset expression.
    valueAtTime(time-offset);
    loopOut(“cycle”);
    Hope you see this, and thanks!
  • Francesco Rampionesi
    February 28, 2023 at 3:24 pm
    this one works very well, but if I add a loop function this one stops to works.
    How can I fix it?
  • Dan Ebberts
    February 28, 2023 at 9:04 pm
    It doesn’t work to add loopOut() to the end of another expression. You have to create your own loop functionality–something like this:
    t = time - offset;
    if (t > key(numKeys).time){
    t = (t - key(numKeys).time)%(key(numKeys).time - key(1).time);
    valueAtTime(key(1).time + t);
    }else{
    valueAtTime(time - offset);
