Activity › Forums › Adobe After Effects › offset expression question
Posted by Nitai Lev-oren on January 13, 2019 at 9:22 amwhat does “loopOut (offset)” does?
and what is the difference between loopOut to loopIn property expression?Walter Soyka replied 7 years, 8 months ago 2 Members · 6 Replies -
Walter Soyka
January 16, 2019 at 8:12 amAn “offset” loop accumulates; it loops the segment you specify, but it offsets the beginning of each loop segment from the end of the last one. A picture might be worth a thousand words:
loopIn() works before the first keyframe (and when you’re defining a range, counts keyframes forward); loopOut() works after the last keyframe (and when you’re defining a range, counts keyframes backward).
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Nitai Lev-oren
January 16, 2019 at 9:26 amthanks, got it!,
but can you explain or give example of the loopIn expression? because I tried it and it doesn’t work -
Walter Soyka
January 16, 2019 at 12:51 pmCan you show a screenshot or two of what you’re trying to do so I can try to explain in the context of your project?
Walter Soyka
Nitai Lev-oren
January 16, 2019 at 1:24 pmthere is 3 keyframes of the red ball one down one up and one down again.
I want to loop it so I placed an expression on the position value:
loopIn(type = “cycle”, numKeyframes = 0)but after the third keyframe the ball doesn’t move
here is a video: https://www.screencast.com/t/23SuuXNqvcna
Walter Soyka
January 17, 2019 at 5:08 pmIf you want to loop that set of keyframes endlessly after the final keyframe, use
loopOut(“cycle”);
Walter Soyka
