Activity Forums Adobe After Effects Expressions Offset blinking expression
  • Offset blinking expression
    Posted by Otávio Nascimento on December 14, 2023 at 7:58 pm
    I’m using a blinking expression inside an ‘else’, but it starts with a random value when it reaches the ‘else’. How to make the blinking start at zero? (I dont know the exact time that will reach the else).
    This is an example in the source text:
    var anyTime = 2.28;
    var cursorSpeed = 10;
    if (time < anyTime) {
    time;
    } else {
    var blinking = Math.abs(Math.sin(time * cursorSpeed));
    "blinking: " + blinking.toFixed(2)
    Otávio Nascimento replied 2 years, 9 months ago 3 Members · 3 Replies
  • Dan Ebberts
    December 14, 2023 at 8:06 pm
    Try changing this line:
    to this:
    var blinking = Math.abs(Math.sin((time-anyTime) * cursorSpeed));
  • Hector Vera
    December 14, 2023 at 8:07 pm
    Is the var anytime equals to the total time of an animation equals 2.28 or is it the time where the blinking animation will start? I suggest screenshotting some of the issues you are having with it so we can better understand how we can help you out on this. For now I do have a video about ValueAtTime expression that may be able to help you a bit. Here it is below:
    https://www.youtube.com/watch?v=xFT6W9uSwbY
  • Otávio Nascimento
    December 14, 2023 at 8:31 pm
    I tried something similar but it didn’t work.
    Here is the full expression in the opacity animator, so you can understand better:
    (‘startAnimationTime’ in the expression below is always zero, so the blinking still starts at a random value)
    var startAnimationTime = 0;
    // animation happening here
    if (thisLayer.name.length > text.sourceText.length) {
    startAnimationTime = time;
    100;
    } else { // animation ends here
    var elapsedTime = time - startAnimationTime;
    var blinking = Math.abs(Math.sin(elapsedTime * cursorSpeed));
    if (blinking < 0.5) {
    0;
    else {
    100;
