Activity Forums Adobe After Effects Offset attached to a Null Object
  • Offset attached to a Null Object
    Posted by David Faircloth on March 22, 2013 at 9:41 pm
    I have the Offset effect attached to a null object, but it does not do anything at all. I’m trying to make multiple objects move up/down will the Offset effect. I rather not have to apply the keyframes to EACH object.
    Why doesn’t this work?
    If I cannot attached to Offset effect to a Null, then I need to come up with a way to Animate the Null off the top of the camera, and back onto the bottom as the top is going off.
    David Faircloth replied 13 years, 5 months ago 2 Members · 2 Replies
  • Todd Kopriva
    March 22, 2013 at 11:14 pm
    Have you applied the Offset effect to all of your other layers, linked their settings to the instance on the Offset effect, and then you’re manipulating the instance on the null layer?
    After Effects team blog
  • David Faircloth
    March 23, 2013 at 1:58 am
    No. I will try that. I’m actually quite new to AE, so I did this wrong I think!
