Activity › Forums › Adobe Premiere Pro › Offlining MTS files in Premiere pro CS5
  • Offlining MTS files in Premiere pro CS5
    Posted by Adam Bromley on August 19, 2011 at 7:18 am
    Can anyone please advise me on a good workflow for offlining footage (.mts) files in Premiere Pro. I can import the files and edit them but if I go to manage media it saves everything in the file and not what is between my in and out points. I need a way to save only parts of each clip that are good and trash the rest. On my last shoot I shot some 20 hours of footage which I need to offline. Can someone please help.
    Adam
    Adam Bromley replied 15 years, 1 month ago 3 Members · 5 Replies
  • Ninetto Makavejev
    August 19, 2011 at 8:40 pm
    You are ticking “create a new trimmed project” in the project manager?
    And determine how large your “handles” should be?
    I don’t know which type of mts files you are dealing with, but I have never had problems creating trimmed projects with the project manager.
  • Adam Bromley
    August 20, 2011 at 1:21 am
    Hi Ninetto, Thanks for your response to my post. Yes, I am checking the create new trimmed project box and specifying handles. I watched a tutorial online and I am doing everything they say. I can’t understand it. I did read on an adobe forum that Premiere Pro is a non-destructive editing tool which means it will never change your source files. It doesn’t make sense though because why have the project manager then? Even if I import 1 clip into Premiere pro, mark in and out points on a small portion of the clip the project size is the same as the output size and it just exports a copy of the entire clip. I am using mts files shot from a Sony NX5u and Sony HVR Z5P.
    Thanks for any help,
    Adam
  • Adam Bromley
    August 20, 2011 at 8:20 am
    Ok I figured out that I have to transcode the files into another format for the project manager to work. I am transcoding to Apple Pro Res 422 HQ. The file sizes are huge though. Is there a better codec with smaller file sizes without significant quality loss?
    Thanks for any help. I’m just trying to figure out the most efficient work flow.
    Adam
  • Alex Udell
    August 21, 2011 at 3:23 pm
    As MTS is like a GOP based format, PPro may not be able to create trimmed copies in project manager.
    So your transcoding to a frame based format DNXHD or Cineform or similar will be what enables that.
  • Adam Bromley
    August 22, 2011 at 1:42 am
    Hi Alex,
    Thanks for your response. Yes that’s exactly it. I have to transcode the files in order to offline clips with the project manager. Makes for a long offline process but it works. Wow, I thought going tapeless would speed up my workflow but it really makes it longer.
    Thanks again, problem solved,
    Adam
