Activity Forums Apple Final Cut Pro Legacy offlineRT stills to full-res
  • offlineRT stills to full-res
    Posted by Neal Broffman on August 11, 2005 at 2:36 pm
    I am working on a project which I captured in offline RT. I have built a section using stills from the video. It appears as if the TC info and reel info is now lost on the stills and therefore cannot be recaptured at full-res (I may be mistaken?). Is there an easier way to recapture this sequence at full-res than to manually re-find the sections of video that need to be recaptured in order to make new stills?
    Neal Broffman replied 21 years ago 2 Members · 2 Replies
  • David Battistella
    August 11, 2005 at 3:31 pm
    If you load the media that is offline in the viewer does it give you a reference TC at the top of the window?
    David
  • Neal Broffman
    August 11, 2005 at 3:47 pm
    The TC does not appear with the still in the viewer window; however, when I control click the still in the timeline and view logging info (in the item properties) lo and behold the TC and reel number are there. None of this info is in the browser. In the browser the reel number is blank and the in and out info does not correspond to the source material. So maybe it will work, after all?
