Activity Forums Avid Media Composer Offline/Online Workflow with Mixed Compression Types
  • Offline/Online Workflow with Mixed Compression Types
    Posted by Olaf Steel on February 28, 2014 at 11:44 pm
    Dear forum,
    I’m sorry if this has been covered elsewhere – I did do a google and Creative Cow search, and got nothing, but could have been using poor search terms.
    My question is this: I’m about to work on an edit that was started by someone else. The project contains media that was transcoded at DNxHD 175x, DNxHD 115, and DNxHD 36 (a result of running out of hard drive space as the project grew).
    Once the edit is complete, I will want to relink to the original raw media and create a sequence of high res clips (presumably all DNX 175x) for online editing.
    Will there be any issues when trying to do this, since the sequences currently contain three different compression types? What are the recommended steps?
    It may be worth pointing out that the original raw media has been moved to other drives than where it was when it was originally transcoded.
    And all media was transcoded, not consolidated, resulting in the .new extension on clips.
    I’m working on an iMac and a Terrablock server for storage of all AVID media & projects.
    Any help with this would be greatly appreciated.
    Thanks in advance!
    Jef Huey replied 12 years, 5 months ago 4 Members · 6 Replies
  • Michael Phillips
    March 1, 2014 at 12:22 am
    Won’t matter at all. The codec doesn’t affect the metadata needed to relink back to camera originals or higher rez media.
    Michael
  • Olaf Steel
    March 1, 2014 at 12:24 am
    Great, thats a load off my mind – thanks!
    I’m assuming the new location of the raw media won’t be a problem either? As long as I know where it is and can point AVID to it, it should relink fine, right?
  • Michael Phillips
    March 1, 2014 at 1:01 am
    Yes, you will be able to relink.
    Michael
  • Glenn Sakatch
    March 1, 2014 at 4:52 pm
    When you are ready to relink, take your working media offline. (move it up one level, outside of the MXF folder is usually the easiest way.
    Create a new bin called Linked clips
    ama link to everything you will need…do it all if in doubt, and place all those links into the “linked clips” bin.
    open your offline sequence
    Select all the clips in your linked clips bin, right click on your sequence and select relink.
    in the relink settings, select “relink to all selected clips on open bins” (thats the links you just created)
    deselect “only link to clips from current project” You may have to play with the options for linking based on tape name/file name, as well as the number of characters at the end of the filename for avid to ignore.
    i also tell avid to ignore extension
    It is worth noting that every now and then i relink and only some of the clips relink…if this happens, try hitting relink again without changing anything in the settings. I have had this work quite a bit lately.
    Glenn
  • Olaf Steel
    March 4, 2014 at 3:31 pm
    Great, thanks so much for all your help. It looks like a simple enough workflow.
    I’ll report back if there are any issues.
  • Jef Huey
    April 27, 2014 at 2:54 am
    I will add only one small comment as I agree with what the others have said.
    All this will work assuming that your workflow was:
    AMA link to camera file > transcode to various DNx media.
    You did not explicitly say that you started with an AMA link. If you did classic import then life will be a bit more painful …..
    Jef
