Activity Forums Apple Final Cut Pro Legacy Offline/Online Frame Accuracy Issue
  • Offline/Online Frame Accuracy Issue
    Posted by Matt Doe on August 5, 2009 at 2:12 pm
    Hello all,
    At my company we work in an offline/online workflow. We offline our material at DV rez and once we pix lock we create an offline sequence through media manager and re-digitize at DVCPro HD for the online.
    Before I began the uprez of the current show I am working on, I ran a frame accuracy check by digitzing a few minutes with TC Burn in from the deck, everything checked out.
    As I began to digitize the offline media at full rez I noticed that while the clip itself is correct, it does not line up frame accurately in the timeline with the reference QT made from the final offline sequence. We have to go clip by clip and slip each by a random number of frames (ranges from 3 up to 17) in order to get the online picture to match the offline cut.
    We are using the following (my company is on the tail end of a massive upgrade):
    Panasonic 1400a
    Running Ref out of an AJA Gen 10 to both the deck and room
    Brand new 8-core, 16gb RAM
    FCP 6.0.6
    Kona 3, latest drivers
    Digitizing to a XSAN 2 w/ 90TB of free space over fiber
    We had this issue before the upgrade, we were running FCP 5.1.4 on Tiger, I was hoping the upgrade would solve this, but now that I run into the issue fresh out of the box, if you will, I was wondering if anyone had any thoughts as to what may be the cause?
    Any thoughts, questions are greatly appreciated.
    Thank you,
    -Matt
    Doug Beal replied 17 years, 1 month ago 7 Members · 10 Replies
  • 10 Replies
  • Shane Ross
    August 5, 2009 at 5:12 pm
    Thoughts….
    Is this 720p DVCPRO HD or 1080i DVCPRO HD? 720P runs at 60fps, so the 30fps DV offline might be throwing off the code? Confusing it somehow?
    Are you capturing via Firewire or via a Capture card? Firewire deck control isn’t always frame accurate, and I have had frame accuracy issues when capturing DVCPRO HD via firewire. Which is why I now capture it via SDI and RS-422 Deck Control.
    Why offline? DVCPRO HD 720p is roughly double the space of DV…maybe 3x the space….not much. And drives are cheap, so why not skip the offline step and capture at full online quality? For the future, of course.
    Shane
  • Matt Doe
    August 5, 2009 at 5:41 pm
    We have run into the issue with both 1080i/59.94, 720p 60 and 720p 23.98 (with the Kona removing the flagged frames).
    We are using Kona 3’s w/ 422 control for our uprez capture, though the offline material was captured on both LHi’s and LHe cards.
    We plan on editing natively for our shows that have less footage, one offs and such. But the majority of our work has such a high volume of offline footage, in the thousands of hours (American Loggers and soon to be Real Housewives of Washington DC) that we would eat up all our 90TB XSAN pretty quick if we were to cut those series natively, thus the offline/online workflow.
    We just installed all new ingest machines and are running tests and ensuring every machine is set up the same, so in the future hopefully that solves the issue.
  • Aaron Neitz
    August 5, 2009 at 5:54 pm
    What’s the frame rate of your offline footage? the 1080i stuff should be simple – but I can see 720/60 and 720/24 causing headaches if you’re offline is DV-29.97
    i have zero experience with the 1400a and DVCPRO-HD tapes workflows. But I do know my Kona 3 system has a much better time with frame accuracy when I REMOVE the Gen10 from the workflow and set everything to input video.
  • Matt Doe
    August 5, 2009 at 5:58 pm
    We cut our 23.98 offlines in 23.98 DV, set-up the Kona as if we were going to capture the HD, except we change the compressor in the Audio/Video settings to DV compression, end up with 720/480 23.98 Anamorphic DV for offline.
    Could that be the issue? We have the Kona doing all the down-converts off the HD-SDI. In the 29.97 realm would taking the down-convert out of the deck be more reliable?
  • Shane Ross
    August 5, 2009 at 6:01 pm
    So your main footage is 23.98? 720p24 with flags? Or 1080i24PA with flags? It might be an issue with how you captured the offline DV. Might see if capturing then reverse telecine would work better.
    Shane
  • Matt Doe
    August 5, 2009 at 6:12 pm
    Would the flags be carried on the downcovert through the Kona? As in, take HD-SDI out of the deck, the Kona downconverts to DV without pulling out the flagged frames, then reverse telecine the DV files to end up with 23.98 offline media? I am not very familiar with reverse telecine.
    The show I am currently slipping in to place is 720/24 DVCProHD with flags (removed by the Kona card for both the offline and online captures).
    The rest of our shows are 29.97, either 720p/60 DVCProHD, or 1080i from HDV cameras that we end up capturing at DVCProHD (we are moving to ProRes for all our onlines from here on out after this current show is donezo next week) for the online, and the DV offline material is downconverted through the Kona for the offlines.
  • David Chai
    August 5, 2009 at 7:04 pm
    We had inaccuracy issues with Deck control capture and layoff until we moved to Blackmagic Decklink. 2:3 pulldown removal perfect everytime. Laying off – frame accurate every time. On Kona 3, 1080p to 720p 23.98 worked with D5, but never worked with HDCAM SR. Decklink, works every time.
    Aja make great hardware, but their drivers for RS422 in FCP are sorely lacking. Try changing the frame offset in the Control settings. They do not change anything.
    I do not work for Blackmagic, this is just my personal experiences.
    David Chai
    Director . Camera . Editor
    http://www.davidchai.com
    dc@davidchai.com
    212 363 0159
  • John Pale
    August 6, 2009 at 3:05 am
    You might want to upgrade to FCP 7. The new ProRes Proxy resolution (very small file size, but still HD) might be easier than the DV workflow you presently use.
  • Ken Jones
    August 6, 2009 at 3:57 am
    I have never had a problem capturing DVCProHD via HD-SDI with a 1400a. The deck seems to work perfectly and doesn’t appear to get “lost” searching for time-code. But, I have always captured entire tapes and have never attempted to “frame accurate re-capture” when working with DVCProHD.
    However, I have had nothing but trouble attempting to capture HDV via HD-SDI with my Sony HVR-1500. Please see my post here: https://forums.creativecow.net/thread/8/1007581#1007581
    And here: https://forums.creativecow.net/thread/126/859595#859595
    The only workaround I have found is to change the deck pre-roll to ten (10!) seconds.
    I attended an Apple/JVC sponsored event last week and I asked the Apple FCP rep about this problem. He confided to me that “Apple really doesn’t care about I/O issues with tape formats”. He said that they really don’t want to change anything if the majority of users aren’t having any issues for fear of breaking something else with deck control.
    A few months ago another Apple FCP tech assured me that this issue would be taken care of “when the new software comes out”. Guess what? I upgraded to FCP 7 and still have the EXACT same issue…
  • Doug Beal
    August 6, 2009 at 12:39 pm
    Hello Matt
    we have issues with HDV that TC is not repeatable.
    We bump any HDV up to HDCam generate new code and move on. in your case thats a lot of expense.
    Depends I guess on how much more time against what deadline in edit VS tape cost for reliable TC
    Any offline/online workflows we work with esp SD from HD we cut with BITC in the letterbox generated by the machine playing the tape. No doubt as to what frame it is.
    If BITC is in the letterbox a simple crop removes it for viewing purposes, If coming from HDCam 23.98 to 29.97 both TC windows are available ORG and PDT (pulldown TC)
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
