Activity › Forums › Adobe Premiere Pro › Offline Workflow with Red files Premiere Pro CC
  • Offline Workflow with Red files Premiere Pro CC
    Posted by Joao Laureano on October 22, 2013 at 2:19 pm
    Hello,
    I’m new to working with r3d files and I am working on a music/doc project mostly shot on RED. I have assembled the footage in Premiere Pro CC (sync audio and footage) but then when I started editing I realised there is no way my Macbook Pro is going to be able to deal with 4K and 5K files, it just won’t playback in realtime even at 1/16.
    So now I’m converting all the footage to 640×480 Apple ProRes Proxy and plan to work offline until client is happy with the edit and then go back to high res for grading. After a few tests I couldn’t find a decent workflow for replacing the original files with low res ones and then back to high res again in CC. I had to go individually on each clip and repeat the same process – offline media, look for the .mov file with the same name, link media, offline media again, look for the original r3d file and relink that.
    Is there any way to optimise this process? I have 2TB of footage to work with so it would save me a lot of time to be able to link and relink media in a batch. My project is neatly organised with the exact same folder structure as the G-Raid external drive several, I’m definitely looking into keep that instead of working with loose files.
    Any advise is highly appreciated
    Joao
    Ht Davis replied 11 years, 7 months ago 3 Members · 4 Replies
  • Alex Udell
    October 22, 2013 at 3:12 pm
    Hi…
    although relinking has been greatly improved in PPro….
    maybe this tool will assist you:
    https://www.retooled.net/?page_id=784
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Joao Laureano
    October 22, 2013 at 5:48 pm
    Thanks for the prompt feedback Alex, never heard of retooled before so will definitely check it out.
    I was just hoping there was a work around this inside of Premiere itself..
  • Alex Udell
    October 22, 2013 at 10:30 pm
    Here’s what I can tell you….
    1) “Multiple clips and sequences can be sent to Adobe Media Encoder at once”
    so you should be able to take your media in the project panel and run it thru AME to create low res proxies in one go. at least according to this: https://blogs.adobe.com/premierepro/2013/09/adobe-premiere-pro-cc-october-2013-release.html
    2) Premiere’s native re-link has gotten better..be sure to look over the docs here:
    https://tv.adobe.com/watch/learn-premiere-pro-cc/using-link-media-to-quickly-locate-relink-offline-files/
    so have a look….you may be able to make this easier yet.
    Alex Udell
  • Ht Davis
    March 3, 2015 at 2:23 am
    If you want to use the proxy preset you downloaded…
    It has to be a preset Premiere can see as a preview preset.
    If you don’t want to drop resolution of the main file, or play with “Fit TO FRAME”, you could use the previews.
    Close premiere.
    On mac, open the .app with a right click and “Open package contents”, you’ll see a window open with the folder “Contents”, in this search around until you see the Sequences or Presets (or both) folder, and find the folder inside that one that’s called “Previews”, and drop the .epr file you downloaded (the preset file) into the previews folder.
    On windows:
    Open explorer (the folder icon at the bottom of the screen or My Computer), and double click your main drive (Most often the C:\ drive). Go to “Programs” folder. Not sure at this point what the exact path is… …But navigate through, trying Adobe, Adobe CC, Adobe CS# folders until you find one that has your Premiere install. In the Premiere folder, you should find a folder that says “Sequences” or the like, and inside that folder there’s one named similar to “Preview”. Drop your .epr files that you downloaded here.
    Open premiere, and create a new sequence. Set up your output target, then look to the preview area. Click the arrow for your codec, select the codec you wish to use (the r3d codec?), and select a preset for it. Now you can select your output size if you want, but some presets already have one set for you.
    Place your clip in the sequence. Render the entire work area. This will create your preview files. You won’t be rendering effects in full target size until you output. This should keep you sane. Adobe has Built in Proxy functions.
    If you still wish to add those .epr lists to your AME, you can import them. Then dump your large files into AME and render out a proxy with those. Open premiere. After you have dropped your clips onto a sequence already: Right click your clips, offline them. Now right click and select relink. When the box opens, choose your newly rendered proxy. IF you have edits already, check to make sure you have rendered the effects in the work area. If it’s still choppy, your drives may not be fast enough. Externals can be faster sometimes, as they use a BUFFERED transfer. Internal drives have only the drive buffer, not a transfer buffer. This means they can only get up to 3gbps for the bandwidth, but spinning drives can only move 300-600mbps max, and that’s used by several read operations for your OS, your editor, your files etc. SO the reads drop in bandwidth and speed very quick.
