Activity › Forums › Adobe Premiere Pro › Offline to online problem in Premiere
  • Offline to online problem in Premiere
    Posted by Jonathan Ledge on February 8, 2014 at 11:24 am
    Hi there!
    I’m editing a pilot for a movie, and I’ve come across a problem I seem unable to solve. I’ve edited smaller rushes from original RED footage, and I want to convert it to the original hi-res footage. I can do this easily by simply replacing the rushes with the original files, because they have the same name and timecode. It’s when I try to relink a clip that has been used several times that this problem occurs. The post house that sent me the material named those clips as following:
    A004_C008_1102HK_001
    A004_C008_1102HK_002
    A004_C008_1102HK_003
    As they appear more than once. The problem is that the clips on the timeline all have the same name (A004_C008_1102HK), and not the _00X extension, which makes me unable to relink all three at once. I can relink one of the clips by pointing towards the A004_C008_1102HK clip.
    I’m sure there is a solution to this, and I would be really happy if someone could tell me how to do it 🙂
    Tero Ahlfors replied 12 years, 7 months ago 3 Members · 2 Replies
  • Morten
    February 8, 2014 at 1:12 pm
    Use replace footage for the 2 other instances, and point to the original clip.
    – No Parking Production –
    Adobe CC, 3 x MacPro, 3 x MbP, Ethernet File Server w. Areca ThunderRaid 8…. and FCPX on trial
  • Tero Ahlfors
    February 8, 2014 at 3:05 pm
    Redcine X Pro is also a pretty useful tool in linking RED stuff.
