Activity Forums Apple Final Cut Pro Legacy Offline to Online edit – timecode slip issues
  • Offline to Online edit – timecode slip issues
    Posted by Adam Kendrick on November 23, 2009 at 10:05 pm
    I have been capturing DVCPro HD footage through a Kona 3 card using the ‘AJAKona3: 525 29.97’ DV setting. Once I edit the footage I use media manager to create a offline project and recapture the footage using the ‘AJAKona3: 1080i 29.97 DVCPro HD’. Media manager is capturing the correct timecode range but I have to slip my video into sync each time. Each time I capture the footage the timecode appears to shift it’s reference to the video. To further confuse matters the issue is not consistent between tapes but is consistent for clips on the same tape.
    Example: I might have to slip every clip captured from REEL1 by :01 frame but every clip from REEL2 might need to be slipped by 1:02. The frame amounts do repeat between tapes but don’t appear to have any relation to clip length. The amount of slip ranges from 00:01 – 01:02. This issue is something I have dealt with on many other projects through several versions of Final Cut Pro. Currently I’ve upgraded my system to FCP 7 and the issue still persists.
    This has added a significant amount of time and frustration to the on-lining process. Is this something that many of you have encountered or is there something that I am doing incorrectly? I’d appreciate any tips/advice on this issue.
    Adam Kendrick replied 16 years, 8 months ago 3 Members · 3 Replies
  • Shane Ross
    November 23, 2009 at 10:51 pm
    I am onlining HDV footage that was captured as DV for the offline. I am capturing as ProRes…and yes, there is some timecode slippage that happens. Heck, I even had this when onlining with an Avid. This is pretty common, which is why I like to have a low res version that I can lay on an upper layer and throw into 40% opacity so that I can make sure all my clips are in sync. I typically have to slip about 40-50% of the footage a few frames.
    Shane
  • Mark Raudonis
    November 23, 2009 at 11:09 pm
    Agree with Shane.
    We do 3 to 5 hours (Final running time) a week of “off-line to on-line” mastering. We’ve built into our workflow a “check” procedure where every shot is checked against the off-line for accuracy. If it’s tape based… you’re going to see some slippage.
    Recently, our workflow has changed to “file based” acquisition, and we’re finding the accuracy to be MUCH more consistent. So, if you’re moving tape, you need to expect to deal with some slippage.
    mark
  • Adam Kendrick
    December 10, 2009 at 3:50 pm
    We too will make the transition into file based media soon but I fear I will still be working on projects with tape media for a few more years. Thanks for your responses I will have to plan appropriately for this tedious task in the future.
    -Adam K.
