Activity Forums AJA Video Systems Offline SD Workflow
  • Offline SD Workflow
    Posted by Bill on August 22, 2007 at 6:03 pm
    What is everyone using as their offline capture format using the Kona3. I seemed to be limited on the formats and DV is the smallest data rate. I have poked around and tried to set it up in a Photo JPEG resolution but it keep looking for a firewire device. I will spend some time running tests to see what works but, in the meantime could anyone share their workflow and settings?
    My source footage is on digibeta which is a standard round trip in 8bit uc. I would like to start bringing in a lot more footage to give me more options when making changes.
    Jeremy Garchow replied 19 years, 1 month ago 2 Members · 4 Replies
  • Jeremy Garchow
    August 22, 2007 at 8:28 pm
    Try DV50. It’s 4:2:2 color space and pretty small file size. There should be an 8 bit to DV50 easy setup.
    How much footage are talking about bringing in?
  • Bill
    August 22, 2007 at 9:16 pm
    a 3 hour mini series. The default is DV which I assume is DV25. It works. It was about 140gb for 190 minutes which seems high to me. I was looking more toward 20-25 gb an hour.
  • Bill
    August 22, 2007 at 9:22 pm
    The Kona 3 Manual states:
    DV50 / 27gb/hr
    DV25 / 14gb/hr
    PhotoJPEG / 9gb/hr
    I used DV25 and it came out around 47gb/hr. I must have done something wrong.
  • Jeremy Garchow
    August 22, 2007 at 11:46 pm
    Yeah, you should be getting around 14GB/hr with two channels of audio.
    To capture in dv, all you need to do is choose the AJA Kona 3 NTSC 8Bit to DV easy setup.
    Jeremy
