Activity › Forums › Apple Final Cut Pro Legacy › Offline & relinking workflow
  • Offline & relinking workflow
    Posted by Accountclosedduetonorealnameused on May 22, 2006 at 2:26 pm
    I will be getting a Final Cut Project in HD for an edit.
    I would like to bump it down to SD to do the edit, (using Media Manager preumably) then basically relink the files to the HD source for final output.
    I will NOT have access to the original tapes so recapturing is not an option.
    My Questions:
    Is this possible to relink to bump down to SD then relink to HD?
    Is there a tutorial of this workflow anywhere?
    Can anyone who has doem this give me any tips/advice?
    thanks!
    Jeremy Garchow replied 20 years, 4 months ago 5 Members · 6 Replies
  • Todd Beabout
    May 22, 2006 at 2:30 pm
    You might want to try this thread:
    https://forums.creativecow.net/cgi-bin/new_view_posts.cgi?forumid=200
    -Todd Beabout
    Vazda Studios
  • Jerry Hofmann
    May 22, 2006 at 2:31 pm
    I think I’d try using the offlineRT HD settings that match the frame rate of your source (using media manger is the way to do this)… rather than SD, which would create much larger files, and if the frame rate doesn’t match, could be a problem later, so use what’s designed to be used for this, and you’ll be home free to reconnect…
    Jerry
  • Accountclosedduetonorealnameused
    May 22, 2006 at 2:46 pm
    ehy Todd, the link brings me to another board, not a topic. broken?
    May 22, 2006 at 2:48 pm
    greatm thanks Gerry. one Q: will the OfflineRT HD conversion yeild files with a datarate simiar to SD?
    (my issue here is drive speed, I know I can do SD, but have not tried HD)
  • Kevin Monahan
    May 22, 2006 at 7:16 pm
    Offline RT is waaaaay smaller than SD. So no worries, mate.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
  • Jeremy Garchow
    May 22, 2006 at 7:50 pm
    Is the project digitized in DVCPRo HD? If so then there’ no reason to recompress into SD. Do you have a Kona2 card or similar?
