Activity Forums Apple Final Cut Pro Legacy Offline on the Timeline But Video Still there?
  • Offline on the Timeline But Video Still there?
    Posted by Paco Sweetman on May 15, 2007 at 2:39 pm
    My external hard drive got switched off while i was working on a sequence, I rebooted the machine and when i openend up my sequence is says that six of the video files were offline on the sequence timeline, yet when I watch them they are fine. Also they do not appear offline in the bins.
    How do I fix this on the timeline? So that they are no longer red and saying off-line?
    Jon
    Debe replied 19 years, 4 months ago 3 Members · 2 Replies
  • Tashi01
    May 15, 2007 at 3:25 pm
    Dear Jon,
    I had this problem before, I am not able to explain why FCP has problems relinking files sometimes.
    Close the Project and re-open it and if these clips still appear to be supposedly “offline” you have two options:
    1. right mouse click on the clip in the sequence: re-link media
    2. overwrite the sequence clips with the ones from the browser
    you could also:
    3. find the Folder “Autosafe Vault” in “Final Cut Pro Documents” and look for the file that was safed before you got cut off. Open it and have a look if you still have the same probelm (would be kind of interesting)
    x-cuse my english cause I m german.
    bye
    tashi
  • Debe
    May 15, 2007 at 9:24 pm
    Or you can trash your Thumbnail Cache in the Final Cut Pro Documents folder and FCP will rebuild it.
    Should solve your issue.
    debe
