Activity Forums Apple Final Cut Pro Legacy Offline Media Error
  • Offline Media Error
    Posted by Sean Barrett on November 5, 2007 at 7:17 pm
    I came to open up Final Cut today and for all of my projects stored on my external drive the media has gone offline. All of my projects on my main drive are fine. This is the message I get:
    I got a “File Attribute Mismatch” message when reconnecting (and I tried it three times.) It said “Some attributes of one or more of the files you have chosen do not match the attributes of the original. This may cause problems within the sequences that are dependent on them. The attributes that differed are as follows:
    Media Start and End”
    I have no clue how this happened I have been working with all my media online. Please help!
    Thanks ten million,
    Sean
    Joefish replied 18 years, 10 months ago 3 Members · 3 Replies
  • Paul Escandon
    November 5, 2007 at 9:01 pm
    Sean,
    Try reconnecting your media – does everything appear normal after you do that even with the warning?
    This has happened to me before. Sometimes my media somehow gets disconnected and FCP will show everything offline. When I reconnect – even though no parameters have changed I still get the mismatch error – I just click through it and everything is fine like it was before.
    See if it works.
    Paul Escandon
    Producer | Director | Editor
    Apple Certified Trainer – Final Cut Pro
    Oremus Productions
    http://www.oremusproductions.com
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Sean Barrett
    November 5, 2007 at 10:36 pm
    Thanks for the response Paul. Yes, that is what I ended up doing and it worked out okay.
    Sean
  • Joefish
    November 15, 2007 at 5:24 am
    hi there,
    I have had some media management problems with FCP too; I recently upgraded to FCP 6 and suddenly i keep getting the message :” The clip’s master is not present. Would you like to add a master clip to the browser”
    It is a new project and i have just added the media: the viewer shows “(name of the clip) in (name of project)” which generally means it is connected to it _ but it’s not!
    any tips or insights on this bane on my editing would be really appreciated!
    cheers
    Joe
