  • Posted by Damian Dunne on October 9, 2006 at 6:28 am
    hey there guys, this is the first time I have undertaken this so I thought I would get some expert help (THATS YOU GUYS!!!!).
    I’m editing a short shot on the Sony F900 though not sure what it’s being captured on. I’m wondering whats the best way to offline it? Is it best to create a mini DV tape and edit with that, though do the time codes match? Or Is there a low res HD codec that will do the trick, so that then all I have to do is swap with the high res stuff via an edl? Any help would be greatly appriciated!
    muchas
    be the ball
    Shane Ross replied 19 years, 11 months ago 3 Members · 2 Replies
  • Uli Plank
    October 9, 2006 at 7:18 am
    The F900’s HDCam is a Sony proprietray codec that can’t be used native on FCP. Normally it’s ingested uncompressed, but that’s huge files and a RAID.
    A pretty good alternative is DVCProHD at only 100mbps (or less, depending on frame rate). It works well from a fast single S-ATA and has decent file sizes. AFAIK DeckLinks and Konas can use it during capture.
    Regards,
    Uli
    Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
  • Shane Ross
    October 9, 2006 at 7:21 am
    I’ll second that. DVCPRO HD is a great codec for offlining, and can be used with FW800 drives. Plus, you can use the exact same frame rate of the HDCAM tapes…which is a huge plus.
    Shane
    Littlefrog Post
    http://www.lfhd.net
