Activity Forums Apple Final Cut Pro offline files not copied to Event folder – no hard drive location info in the event or the properties tab
  • offline files not copied to Event folder – no hard drive location info in the event or the properties tab
    Posted by Dave Jenkins on February 4, 2013 at 6:12 pm
    I have files that are offline and not copied to the Event folder and there is no hard drive location information in the event or the properties tab to know which hard drive these files came from.
    Is there a solution to this?
    Dajen Productions, Santa Barbara, CA
    MacPro Two 2.66GHz Quad Core – AJA Kona LHe
    FCS 3 OS X 10.7.4
    FCP X, Adobe CS6, Logic Pro, Squeeze, Filemaker
    Jeremy Garchow replied 13 years, 7 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    February 4, 2013 at 7:22 pm
    [Dave Jenkins] “Is there a solution to this?”
    Not without a manual search, no.
    It is possible, if using aliases, that the file could have moved. If you “Show File Status” in the inspector, it will show you the filename of the offline file. Do a spotlight search with one of the filenames and see if it has changed directories.
