Activity Forums Apple Final Cut Pro Legacy Offline edit workflow
  • Offline edit workflow
    Posted by Ben Murphy on July 29, 2009 at 6:21 pm
    Hi Everyone,
    If I am editing HD footage, how do I compress the media to an offline size and then, after picture lock, conform the sequence back to the original format?
    Ben Murphy replied 17 years, 1 month ago 4 Members · 4 Replies
  • John Pale
    July 29, 2009 at 6:43 pm
    Search FCP Help for Media Manager. The process is fully explained.
  • Nick Meyers
    July 29, 2009 at 7:28 pm
    to compress:
    select all the media,
    open Media Manager.
    – Recompress Mode
    – Set to media format of your choice Offline RTHD in FCP6, new flavours of ProRes in FCP7
    – DONT delete unused
    – Base Media FIle Names on: Existing File Names.
    probably best to ask for a new project containing the media
    to go back:
    – Create Offline Mode in MM.
    – Set to Sequences to: your HD format
    you get a new project with a sequence full of offline clips (“offline” as in no media)
    Reconnect to your HD.
    nick
  • Mark Raudonis
    July 29, 2009 at 8:23 pm
    I would add to Nick’s steps:
    Test. Test. Test.
    Be sure you’re comfortable with this process before committing to processing all of the media.
    Good luck.
    mark
  • Ben Murphy
    July 29, 2009 at 8:25 pm
    Thanks for all the help guys!
    You guys rock.
