Activity › Forums › Apple Final Cut Pro Legacy › Offline clips still show up when sequence is played??
  • Offline clips still show up when sequence is played??
    Posted by Katrina on April 8, 2005 at 3:25 pm
    Hi all,
    I’m revisiting an old project in which several media files are apparently missing. The clips are labeled “offline” in the timeline and I can’t locate their media files anywhere on my computer, and yet when I play the sequence the so-called missing clips still show up as if there was no problem. Does anyone know what’s going on? Thanks!
    Katrina
    Kevin Monahan replied 21 years, 5 months ago 3 Members · 2 Replies
  • Matthew Brunn
    April 8, 2005 at 4:15 pm
    It could be that these clips were rendered and it is playing the render even though the master clip is offline. Drag the “offline” clip to the browser and if it is still off line in the browser,if so, then I would go to your “rendered” files and trash them. I assume that you didn’t want them to play anymore. Hope this helps-
  • Kevin Monahan
    April 8, 2005 at 7:29 pm
    I bet it’s just the thumbnails in the Timeline showing them offline, no? For that you just dump the still cache files. Check the FCP docs folder.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
