Activity Forums AJA Video Systems Offline capture AJA-IO LA
  • Offline capture AJA-IO LA
    Posted by Chris Pittman on September 12, 2007 at 2:03 pm
    I am working in an environment with incredibly limited storage. I am currently capturing roughly 4 hours of industrial footage using the AJA IO LA interface. I can set up Offline Sequence settings but the AJA doesn’t seem to have a corresponding Offline Capture quality setting that will keep capture disk space to a minimum and I REALLY MEAN MINIMUM.
    I have tried a couple of things but am getting no real space savings. The only thing I can do is capture 8 bit and recompress using Media Manager.
    Anybody else with this problem?
    Chris
    Walter Biscardi replied 19 years ago 3 Members · 4 Replies
  • Jeremy Garchow
    September 12, 2007 at 5:33 pm
    Do you know how to use the Io LA and the easy setups?
    Hit control-q and choose form the myriad of inputs and codecs.
    I would suggest capturing to DV and not 8Bit. This will also allow real time previews of footage, unlike offline rt.
    Hit control-q and choose the AJA IO ‘choose an input’ 8 bit to dv.
    Jeremy
  • Chris Pittman
    September 12, 2007 at 7:02 pm
    Hi Jeremy, thanks.
    I know about easy setup but I find that the DV codec is looking for a
    firewire device and I need to log using RS-422 from BetaCam.
    A few days ago I created an easy setup on this same project but in comparing
    “original to modified” clip size,I wasn’t saving much space on the drive.
    Chris
  • Jeremy Garchow
    September 12, 2007 at 7:17 pm
    Have you installed the io drivers?
  • Walter Biscardi
    September 13, 2007 at 1:36 pm
    [chrisondoradrive] “I know about easy setup but I find that the DV codec is looking for a
    firewire device and I need to log using RS-422 from BetaCam.”
    Did you simply choose DV-NTSC (or DV-PAL) or did you choose the AJA 8bit to DV Easy Setup? You need to use the AJA Easy Setup.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
