Activity › Forums › Adobe Premiere Pro › Official Adobe bug and request post???
Posted by Alex Rod on April 22, 2013 at 7:47 pmis there an official place to put bug reports and feature requests for Ppro?
Kevin Monahan replied 13 years, 5 months ago 3 Members · 4 Replies -
Angelo Lorenzo
April 22, 2013 at 7:58 pmWhile Adobe employees float around this forum, their forums, and other major forums, this official form is the only formal way to submit bugs and feature requests https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter -
Alex Rod
April 22, 2013 at 8:04 pmthank you Angelo –
I’ve looked, but I think I should ask before I request it.
you know how in final cut i can click on the program window and just move the clip around and size it just by dragging a corner?, could I do such thing in PPro? -
Angelo Lorenzo
April 22, 2013 at 8:27 pmNot sure I understand what you mean. If you want to scale or move a clip within the program monitor then go to Effects Panel and highlight the clip’s motion effect. This will allow you to manipulate your image directly in the program monitor.
Kevin Monahan
April 22, 2013 at 8:55 pmYes, that link is correct.
[Angelo Lorenzo] “then go to Effects Panel and highlight the clip’s motion effect. This will allow you to manipulate your image directly in the program monitor.”
You can also double click on the clip in the Program Monitor. That should also bring up the handles for scaling and to move or rotate the clip. Note: this only works on the upper most track.
Kevin Monahan
Social Support Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter!
