Activity Forums Adobe After Effects Odo’s Change Shirt Morphing Effect
  • Odo’s Change Shirt Morphing Effect
    Posted by Kwaku Nyantekyi on February 27, 2009 at 5:09 pm
    Hello. I was wondering if anyone had any ideas as to how they pulled Odo’s shape shifter change clothes effect so seamlessly from setup to post. And how to pull this off in After Effects.
    https://vimeo.com/3310209
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Kwaku Nyantekyi replied 17 years, 6 months ago 2 Members · 2 Replies
  • Mark Suszko
    February 27, 2009 at 5:36 pm
    Well, the overall shape and cut of the two outfits is quite similar, so a track and roto is my first guess. Since they have a lot of digital models for the Odo character, it might just be a matter of substituting one of the entire body models or the body, sans head, just before his arms come down, then you’re just altering the texture and bump maps to make the clothes seem to change. Finish by morphing back to the live Odo head, and find a spot to cut away as soon as you can. The lapels hardly seem to change at all. It was impossible for me to frame-by-frame this vimeo playback, so that’s the best I can suggest.
  • Kwaku Nyantekyi
    February 28, 2009 at 8:42 pm
    Thanks for your input Mark. It is indeed tough to analyze when you view it frame by frame.
