Activity Forums Adobe After Effects Expressions odd viewport behaviour w/continuously rasterise on
  • odd viewport behaviour w/continuously rasterise on
    Posted by Jimmy Brunger on November 10, 2011 at 4:19 pm
    Hoping someone else might have had this problem in the past….
    Built a basic map using masks and various colour overlays, bevels, etc which I want to move around and fly close into with camera. each country border is a sep mask all on the same solid layer. I have an expression on each mask (below) so I can change the gap between each country with a slider in the parent comp depending on how far I am zoomed into map. Also a similar expression used to control bevel so that it looks right at diff magnifications…
    NOW, I need the CR button checked so map doesn’t go soft when zoomed in close, but when this switch is on my comp behaves very strangely….if I move the camera at all or set any camera keyframes nothing is updated in viewport/comp window. However if I then RAM preview the same couple of KFs it shows me my camera move. Purge cache and then tap through and it shows me the movement, but when I actually physically move the camera or type any new values in I don’t get an update….
    CR button switched off and my comp behaves as you’d expect, albeit VERY soft and pixellated.
    NOTE: This is only a problem when using the camera – if I scale, position or rotate the comp it works fine..but obviously not ideal for animation of a scene.
    Any ideas guys!?
    Thanks for any help you can offer,
    Jim.
    comp("PARENT COMP").layer("Control").effect("Mask expansions")("Slider")
    value+comp("PARENT COMP").layer("Control").effect("Bevel")("Slider")
    Production Premium CS5.5 – Mocha v1.5
    MacPro 3,1 8-core 3.2GHz / 32GB RAM / NVidia Quadro 4000 / OSX 10.6.8
    Decklink Extreme+ 3D / 3TB RAID-0 local / 6TB XServe + United Digital RAID on 10GbE
    Jimmy Brunger replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
